Anyone using AT&T Yahoo web mail?
  • Anyone using AT&T Yahoo web mail?
    I have a strange glitch on my home PC -- I use AT&T Yahoo DSL as my ISP. So I use the Yahoo mail web interface to screen all my email and delete the stuff I don't want before downloading it permanently to my PC using Thunderbird.
    When I have the Advanced mail interface up, the upper pane where all your message subject lines are listed for the current folder is missing the scroll bar on the right side of the pane. ????? I normally have 100's of messages in my Inbox so the pane should always have a scroll window. I primarily use Firefox 3.5 as my browser, but also use IE.
    When I get into the same web mail interface on my work PC, the scroll bar is there, so this is something hosed up on my home PC. I have WinXP at work, and Vista Home Basic at home.
    Any ideas how/why the scroll bar is gone, and how I can get it back?
    Regards,
    Al
    All my equipment & my DVD collection
    is it a bad temp file or something like that ???? but that wouldnt explain why it doesnt work in ie or firefox.
      Can you log on as another person on the home PC to see if issue still exists?
      This will tell you if it is more software/PC related or Profile related.
        Still bad on FireFox, but OK on IE
        I tried both browsers again and I was incorrect on IE - it has the scroll bar. Only Firefox is messed up. I tried switching from their Advanced mail interface back to the Normal mail interface and then back again to see if it would "reset". No joy.
        Regards,
        Al
          I would blow out all cookies and temp files and see what happens
