Worth a try since someone among us may be PC tech-type.
I get the following screen upon shutdown with a new XP Home SP3 machine:
A problem has been detected and windows has been shut down to prevent damage to your computer.
KERNEL_DATA_INPAGE_ERROR
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.
Technical information:
*** STOP: 0x0000007A (0xC05805F0,0xC00000A3,0xB00BEB6E,0x654FA860)
*** usbhub.sys - Address B00BEB6E base at B00B2000, Datestamp 480254d0
