X-Box 360 help Please
  • X-Box 360 help Please
    Hi Guys,
    All of a sudden and for no obviously reason, my daughters X-Box is only presenting in black and white. Checked all the connections, tried changing inputs, checked the projector and pre/pro. Checked the manual and no help there. Has anyone here seen this issue or can point me to a helpful X-Box forum?
    Thanks,
    Cleverly disguised as a responsible adult.
    What's your video connection type?
    Black and white instead of color would occur if you were using component and only the green/luminance signal was getting through.
    Wes Miaw, Neko Audio LLC
    www.NekoAudio.com
      I have had a few friends' xbox cables malfunction. Borrowing a cable (or purchasing a used cable) would be a simple test.
        Thanks guys.
        I think it was the cable. While I was screwing around with it, I realized the darn thing had an HDMI out, so I hooked that up and problem solved.
        Thanks again.
