The A2 is a pretty large center channel speaker. I'd prefer to find a cabinet which will hold my A/V equipment and have a shelf large enough for the A2 to sit on. My last option would just be to put the A2 on top of the cabinet itself since the TV will be wall mounted above everything. So far, I have only found cabinets that are very expensive which have a large center channel shelf. I'd prefer to stay under $500. Anyone who has an A2, what are you using to support it? Please provide photos and product info, if possible.
TV stand / credenza that will fit Arx center channel?
I use something like this for the A2 http://www.amazon.com/Peerless-Adjus...ref=pd_vtp_e_1 Just mounted it right above the TV.
Originally posted by gtpsuper24I use something like this for the A2 http://www.amazon.com/Peerless-Adjus...ref=pd_vtp_e_1 Just mounted it right above the TV.
This is the one I have and it works perfectly.
http://www.meijer.com/s/home-styles-...ony/_/R-131696
I have an onkyo nr809 which is a big receiver and it fits fine. For extra airflow I did not install the back piece to the enclosed part of the cabinet. If you did this as well your receiver would fit. I measured and with the glass doors shut, it is 18" to flush at the back of the cabinet.
