Well I finally got my second UFW-10 back and it sounds fantastic. I am using a Denon 2805 with only 1 sub output. I have the output split and a line run to each sub. Crossover set at 80hz.
What is the best way to set these up:
1.Do I set the gain to the same on both?
2.Do I set each one up by themselves and then hook them both up?
3.How do you go about setting the Parametric eq's on each of them?
4.Should I plug into the LFE port or use a splitter and plug into the L&R ports on the sub's plate amp?
IN other words I don't know how to freaking set these up. Contemplating a Behringer 1124...but will wait for a sweet deal on one.
Any help would be appreciated.
