Hey guys I have been reading for quite some time on avs and cht forums. I am doing the finish work in my theater. I followed all the build advice on avs with the help of bryan pape (awesome guy). I have the stage with sand, decoupled walls, riser with insulation and 2 layers of 3/4" supress drywall with green glue in between. Room dimensions, are 24x15 screen wall is at 21 feet. 7'10" ceilings Im ready to rock.
I am running all arcam fmj gear, Ati amp, and Energy c-9/veritas speakers. If I do change speakers, which i have no reason to, I am going to the Klipsch rf-7ii setup...
I am currently running dual av123 mfw-15s, they are nice but i need more, I have lots of acoustics and bass traps in the room.
I Honestly dont know which subs to get I am leaning towards CHT subs, just not sure which ones. Bryans design has dual subs dead center front and rear. I dont have room between my last row of seats to fit any of CHS subs. He also recommended all 4 corners. Like I said I am happy with the mfw-15s just want to feel and hear more without getting crazy. Appreciate throwing out some recommendations as to which subs or set up to go with from chase. thanks
jamie
jamie
