Experimenting with other amps
  • Experimenting with other amps
    I am starting this thread to discuss other amplification for the SS-18.2 and 18.t that I have personally experimented with.
    So far I have tried the following with my ss-18.2
    Dayton SA-1000
    Crown XLS-602
    QSC USA-1200
    Phonic MAX-2500
    Adcom GFA-555II
    Crown XLS-1500
    Mackie 1400i
    I will be providing writeups for each one of these. Just getting the thread started up at this point, don't expect any scientific graphs or anything as that's a little above my head still (don't have the proper equipment to take measurements) Will be more or less subjective commentary.
    Current System
    Amps Sunfire TGA7400
    Mackie 1400i
    Crown XLS-1500
    Receiver:Sunfire TGP5
    Speakers: Klipsch KLF-30
    Jamo D8 CEN
    Chase SS-18.2
    2x Lilmike Cinema f20
    Video:Epson 3010 3d 1080p, 130in perforated screen
    Dayton SA-1000
    Crown XLS-602
    QSC USA-1200
    Phonic MAX-2500
    Adcom GFA-555II
    Crown XLS-1500
    Mackie 1400i
    If you own a spl meter you culd still take measurements for comparisons. Run a 10hz test tone, then 15hz, and then 20hz, etc.... and measure with your spl meter on how loud it is(it does not have to be accurate as this is just comparing the amps level differences). Just turn it up until it sounds bad to you and call it your max spl at each frequency. Then change amp and see if the dBs change at all. Maybe one will be higher at 10hz, etc....
      unfortunately I no longer own the xls-602 or the sa1000 so that would be impossible.
      Current System
      Mackie 1400i
      Crown XLS-1500
      Jamo D8 CEN
      Chase SS-18.2
        It is OK, do what you can.
        How do the F-20's sound?
          they sound good, the real challenge is integrating them with my 18.2
          Current System
          Mackie 1400i
          Crown XLS-1500
          Jamo D8 CEN
          Chase SS-18.2
            Looking forward to your reviews. Thanks for taking the time and sharing.
              If and when I ever get my subs, I can measure mine with my Crown XLS-5000 and an SPL meter.
                Thanks guys for offering up these comparisons like this. :)
                  just as I fire up this thread I get SUPER busy at work. I'm now out of town and won't have time to do this for about 2 weeks.
                  Current System
                  Mackie 1400i
                  Crown XLS-1500
                  Jamo D8 CEN
                  Chase SS-18.2
                    Did you ever get around to finishing this? I looked for other posts and I didn't see it, but it's very possible I missed it too. Basically, I'm ordering a SS-18.2, and am wondering if there is a better amp I could get for around the same price or if the Dayton is a very good bang for your buck amp? I'd certain it's a great choice as its the one they sell with their subs and they wouldn't want to use a inferior product that could make their products perform worse, but I always like to look at available options. :)
                    Thanks!
                      Thanks!
                      Same here Stormwind13, thinking about getting a Crown XLS-2000 for my single 18.2 to run with a Denon 4311 and XT-32.
                        I never got around to posting my impressions because work got so busy. By the time I did, some of the amps I had sold.
                        I currently use the mackie 1400i with the chase ss-18.2 I find that right around 1500 good clean watts is a great starting point. I felt that the mackie had a little more snort then the crown xls1500.
                        I still use the xls- on my pair of cinema f20s
                        Current System
                        Mackie 1400i
                        Crown XLS-1500
                        Jamo D8 CEN
                        Chase SS-18.2
                          Well I have a Crown XLS 2000 on order and will post my impressions after setup and testing on a single 18.2. :D
                            Thanks Mike! :)
                              I found the xls-1500 to be lacking a bit on the 18.2, don't get me wrong the sub will pound with that amp- but the amp runs out of steam before the sub does.
                              I'll be interested to hear about the xls-2000
                              Current System
                              Mackie 1400i
                              Crown XLS-1500
                              Jamo D8 CEN
                              Chase SS-18.2
