I have been looking to replace my Def Tech Powerfield 1500 I use in a 21x16x13 room, one side is partially open. I use my system 80% music and 20% movies TV. I am seriously considering the Chase offerings. I like the great price on the SS-18.2 but I think the SS-18.1 with two I could get a smoother response in my room. Any sound differences between 18.1's and an 18.2? Also on the products page it says more amp will become available, would I be better to wait on a better amp than the Dayton offered. I think two 18.1's would be more esthetically pleasing but I like the value of the 18.2. Any advice is appreciated. Also when people are posting charts of their subwoofer frequency response curve what software or equipment are they using to do this?
SS-18.1 vs SS-18.2
Bigotis - We are down to a couple of "C" stock cabinets in the SS-18.2.
The SS-18.1 as a pair and the SS-18.2 are identical performers, with (as you mentioned) the SS-18.1's having the ability to be placed apart to smooth out bass.
In regards to amps, all the affordable amps we keep getting promised are not yet available to try. The Dayton is a great choice for driving a pair of SS-18.1's.
If you are feeling adventerous, you can look into the Crown XLS-5000 thread here: Gorilla83's XLS-5000 Thread
Craig, can the Dayton Amp drive two SS-18.2s?
Originally posted by craigsubBigotis - We are down to a couple of "C" stock cabinets in the SS-18.2.
Sunless,
For what it's worth, I'm 40/60 music/movies and just placed an order for dual 18.1's.
I'll post a mini review once I get them, setup and dialed in, etc. but I'm coming from a single Axiom EP500 (previously dual EP500's).
I'm sure the dual 18.1's will crush the single axiom, we shall see. :)
DanaDana
Zu Omen Def's, M22's, QS8's, CHT SHO-10, Dual CHT SS-18.1's, Onkyo TX-NR3008, Mitsubishi WD-73740 73" DLP, Sony PS3
Originally posted by SunlessStrawhatCraig, can the Dayton Amp drive two SS-18.2s?
Each SS-18.2 has two, 8 ohm drivers in the cabinet which are wired to present a 4 ohm load to the amp. 4 ohms is the maximum the Dayton amp can handle. So, each SS-18.2 requires one Dayton SA-1000 amp. :)Jack
Thank you, Ajax.
Originally posted by MktheaterHell no! I know the performance is supposed to be the same with dual 18.1's as a single 18.2 but once you spread them out the 18.2 will have more output. Don't forget that!-Greg
Originally posted by HuskerOmahaYou could definitely tell that at the October GTG.
A single SS-18.1 and stacked SS-18.1's will be identical.
I don't recall trying spread out SS-18.1's at the GTG ... did I miss something?
Originally posted by HuskerOmahaYou could definitely tell that at the October GTG.Originally posted by craigsubGreg - MK meant that taking two SS-18.1's and spreading them out will have them delivering less SPL than an SS-18.2.
Originally posted by MktheaterI think all the subs were spread out near the front two mains. So actually a single 18.2 would have more output and duals would have been interesting especially with a clone amp or even better each sub having a plate amp with DSP from the same company the submersive uses. Yes the 18.2's would have cost $1500 each with amp and DSP but at $3000 for the pair it would have still been a lower cost option. Is that company speaker source or speaker craft, I don't remember.
I think you mean the 1-14 meet?
