Hello Everyone,
This is my second post here. I have ordered 5 SHO-10s and will receive them tomorrow. I am just another HT enthusiast but not as knowledgeable as the most of the people in this forum.
I have always been told that "sealed and ported" subs should not be used together. I wanted to see the reason behind this suggestion and did some testing last weekend.
My room is 19x14.5x8. The front stage has been covered with linacoustic and has OC702 in the corners as bass trap. The ceiling has double drywall with green glue in between. The entire room has 48" high linacoustic around. 3 sides of the room has cement walls.
By gogunbaba at 2011-02-22
subs: ED-A5 350 (first gen) and 24" cube sealed MAELSTROM X w/ EP4000
The receivers volume is set to -20 and SMS-1's volume is set to 15
2 subs running together and the mic is on the right back seat
in room response
the mic is on the right front seat (both subs running)
the mic is on the left front seat (both subs running)
the mic is on the middle back seat (both subs running)
the mic is on the floor ,back of the room right corner (both subs running) I think this is the loudest point in the room (to my ears)
The next post will have the individual sub results. :applause:
in room response
