Is this subwoofer worth buying?
  • Is this subwoofer worth buying?
    Recently I came across the opportunity to buy the Gateway KAS 303 speaker system for $115. The subwoofer that comes in the system is supposedly a HSU STF-2 in disguise, the the speakers supposedly the Ventriloquist speakers.. Do you guys think it'd be worth it? Thanks!
    Some links I found regarding it:
    KAS303 Sub is an actual HSU Sub
    More Stuff on it..
    The sub is about 6 years old, but , assuming it's a Hsu product, should last a good time, right?
    Thanks in advance!
