Just got my replacement amp for the UFW-10. When I opened the sub to replace the amp, the inside cabinet was not lined. I'm not too familiar with the rest of the UFW-10 or ULW-10 but the unit reviewed here http://www.audioholics.com/reviews/s...-ufw-10/page-1 mentioned that the inside was lined with a 1/4" felt batting. Instead, my unit came with polyfill. Is the polyfill a comparable replacement for the 1/4" felt? The reviewer didn't even think the sub needs insulation. :no clue:
Is it worth getting better damping material such as the BH5 for the UFW-10? All the MDF except the front baffle (0.9") is 0.7" thick. Since this is a smaller unit compared to the UFW-12 would the No Rez work as well?
I have not connected the latest amp to test its performance. It appears to be a modified Dayton SA240 amp (http://www.parts-express.com/pdf/300-804m.pdf). The replacement amp is rated 400W as opposed to the 650W that it's replacing. The original design was rated 500W. I'm not sure how the sub will perform with this latest amp, or if the BH5/No Rez is worth the investment given the sub's configuration and components.
