I hope everyone had a great summer! Craig and many other members helped me back in March select my first subwoofer (I included those original post links below). I could use some NEW advice. Thanks in advance!
I've been enjoying the Rythmik F12G subwoofer I bought back in March. Recently I purchased the Oppo BD-83 BlueRay deck. I have had the sub setup the same for the past few months for music playback. I'm still using an Onkyo 906 AVR and the Audyssey settings, meaning the subwoofer is set to crossover at 80 kHz. Now that I am viewing and listening to BlueRay movies I have a NEW question. I have watched the BlueRay version of "Iron Man", there is a fair amount of low end SFX. In some scenes when he is taking off, there is the sound effects of "rocket boosters", like a missile taking off, very LOW end DEEP sound. I had no neighbors above or below me those times, so I turned the AVR volume up to near what I guess is called "reference volume level", on my AVR that is near "ZERO db". The dialog and music were fine and my other 7 speakers did okay even though none are rated above 125 watts, the AVR can put out 145 watts/per channel. When the sound effects I described above play, the Rythmik sub seems to handle it okay at first but these low end effects can last for quite a long time, and then the sub starts to sound like it is "rumbling". I put my hand in front of the sub's cloth screen and the air from the sub was pushing it out quite a lot, so I turned the volume down. I just played the first Pink Panther "remake" starring Steve Martin. Near the beginning of the movie there is a scene where he accidently spins and pushes a huge planet "globe" down a long set of stairs and into the street below. The globe bounces and there is a great deal of low freq audio here as well. In this case I had the AVR volume at about -15 db, dialog and music were at a good listening level. The low freq SFX again, seemed to "rumble" and are very LOUD or should I say "powerful" compared to dialog/music volume setting. I use the "bitstream" setting from the Oppo BlueRay deck and let the AVR do the decoding, in most cases on new BlueRay's it's "DOLBY TRUE HD", and it lets Audyssey do it's thing. I have NEVER had a true "sub" before, so I am a newbie with it, and am concerned not only about the rumble, but the amount of AIR that is pushed by the speaker cone, it's scary, not sure if it should be moving that much air, pushing in and out?
Please, if anyone has time to take a look at my sub settings below, and tell me if there is any setting on the sub that might help in these cases? I would have to reach behind the sub and change the settings when going back and forth from Movies to Music, but I'm not against that to save this thing from blowing up! I'm not sure if the high volume was the only cause of the rumbling I heard, but I did not want to damage the sub and wanted to wait till I could post here. Other then that I am enjoying it very much, and have recommended it to my friends to buy.
CURRENTLY USED SETTINGS FOR "RYTHMIK F12G" SUBWOOFER, for AUDIO CD MUSIC & BLUE RAY MOVIES
SUBWOOFER PLATE AMP "A370" SETTINGS USED:
PEQ = OFF
DELAY/PHASE = 0 MINIMUM
CROSSOVER = 120 Hz MAX NOTE: I have the AVR set to 80 kHz Crossover in speaker setup, NOT sure if this 120 hz setting is correct for me?
LEVEL = AT 1:30 o'clock ON DIAL (to attempt to acheive "O db" settings after running Audyssey)
SUBWOOFER:
LOW PASS = EXT/12
RUMBLE FILTER = ON
EXTENSION FILTER:
FREQ = 14
DAMPING = HI
ONKYO 906 AVR AUDYSSEY SETTINGS:
SP LEVEL:
LEFT: -3.0 db
RIGHT: -3.0 db
SUBWOOFER: 0.0 db
EQUALIZER SETTINGS on AVR:
"DYNAMIC EQ". (After Audyssey is run the EQ on Onkyo AVR is set to this filter preset).
========= MY ORIGINAL POST LINKS ===============
http://www.tweakcityaudio.com/forum/...read.php?t=662
http://www.tweakcityaudio.com/forum/...read.php?t=672
PEQ = OFF
SUBWOOFER:
LOW PASS = EXT/12
RUMBLE FILTER = ON
EXTENSION FILTER:
FREQ = 14
DAMPING = HI
SP LEVEL:
LEFT: -3.0 db
RIGHT: -3.0 db
SUBWOOFER: 0.0 db
