10" $150 Subwoofer Comparison
  • 10" $150 Subwoofer Comparison
    Hello Dere.
    TSC ASW-10
    Dayton SUB-100
    Can anyone give me the run down on how these two subs compare with each other? They're similarly priced, but the TSC ASW-100 seems to be slightly better with a better warranty and less failures, according to reviews (although it also has less reviews, and probably isn't time tested).
    Is the Dayton subwoofer one of DR's designs?
    Are there any other subs in the price range that'd be comparable? Thanks!
    If you're looking for a smaller sub on the cheap, I have a 10" AudioSource sub I'm not using anymore..
      What model is the sub?
        It's the PSW100
          PM'd =)
            I had the old Dayton 10" sub that was a hit over at AVS. I was blown away because I had only known my old Dell computer cub that came with the boston acoustics speaker package (maybe it was gateway). Anyway, it really will only work for very small rooms in my opinion.
