Life comes at you fast...let's just say that changes in my life won't allow me to shoehorn a used set of LS6's into my place. I can't use that WAF term for my situation...but GFAF is half way accurate. Oh...and uhhh...I can't even play my minis too loud anymore.
Problem: The woofers in the minis will not play low enough...so I need a sub that will dig deep at low volume levels...and stay flat up to its crossover point. Huge db peaks will not be tolerated.
Solution: I'm thinking Velodyne DD series...used of course? I figured I can use the EQ to get a flat response to includee the lower hz area. Very little boosting of frequencies will be done...but I'm willing to cut em all day to get flat. So...that's why I'm ok with the lower ouput comments re the DD sries that I keep running into.
End result: I want bass that's labeled: accurate, clean, fast, quality, low. It has to be damn good at music and good at HT. By the way...I don't care about slam.
What do you ladies and gentlemen think?
