So I got to thinking ok, the staiks are just not cutting it in the bass department and there appears like there is going to be a significant wait for the new amps. Which, if they are done right, I can deal. So been looking at getting an external amp that I could use if I ever decide to build a DIY sub. Hmmm... well why the hell can't I set up a good receiver and go from there?
That's just what I did. I had a old Yamaha receiver (which IMHO sounds better then the Onk), took the amp plate off, unhooked the speakers terminals from the amp, plugged in the LFE to the right channel of CD (which it could be any input on the receiver) wired up the right side of the receiver outputs and voila! Back in business.
That said, if you have an old receiver with a dead amp here's an option to get one or two depending on how you go about going and have some bass again. Think I'm kinda like Jason when it comes to bass. I like to feel it..
