I just brought this up in another unrelated thread, but thought I'd share.
Most if not all AVR's are of the 7 channel variety. But many of us only use 5 channels of the amp. These avr's are usually configured to have the option of running the 6th and 7th channel as a multi-room option as well.
This is something I did years ago, and it worked better than I could've imaginged.
I configured the 6/7 channels for multiroom. I ran a y cable from the LFE channel (so it was already crossed over) to a spare input on the avr. I then assigne the multi-room source as the source I plugged in the split lfe into.
I ordered 2 of these and mounted them to the frame of the sofa. When I wanted the shakers, I just turned on the multi-room feature, and voila....I even had separate volume control from the same main remote, to control the shakers independent of the main volume.
Just thought I'd share....it's a relatively cheap tweak that is fun. I posted this years ago over on av123, but I haven't heard of many that have tried it. It worked amazingly well.
