Anybody here using an SVS for a dedicated 2 channel rig, particularly the PB13?
Curious as to which tuning mode you run. I finally moved mine up to the 2 channel system late last night, and am having troubles dialing it in. There were a couple of subs in there before (not running stereo), but the mains were running full range.
Now that the SVS is in there, I'm using the high pass on the sub amp to the mains. Something isn't quite right. I don't have the cohesive sound I used to have with the (much) older subs.
Just curious if there are any out there successfully using a PB13 in a 2 channel setting, and maybe offer some help dialing it in.
