They're Here!!!
Here are my impressions of my newly arrived Arx A2! I will be using 2xA2s in Stereo in a Nearfield Computer setup. More on this later.
Packaging and Unpacking
The Arx A2 comes Single-boxed, yet is extremely well packed. The speaker comes wrapped in a plastic bag and is protected by huge foam square inserts. These foam squares fit right over the bottom and top of the speaker. There is nearly no wiggle room in the shipping box. A port plug comes in a plastic bag. My two Arx A2s did not come with any instruction manuals, warranty cards, or accessory 'rubber feet' found in most bookshelf speaker packages. An online instruction manual can be found on the Arx A2 product website.
Cabinet Shots
Like the prior Acculine models, the Arx are a 'no-frills' speaker design that comes in a Simulated Black Ash PVC wrapped cabinet. Yep, its a boring black box, but looks aren't entirely everything. I was immediately surprised at the size of the cabinet.... probably one of the largest 5.25" MTM cabinets I have ever seen. It packs a hefty weight, nearly 25 lbs! When I wrapped my knuckles on the cabinet, it seemed pretty solid enough. It wasn't a completely dead thud, nor a hollow wooden sound. The surface of the cabinet is much smoother compared to the original Acculines even though the texture seems to be very similar. Turning to the rear of the cabinet, the overly large bass-reflex port caught my attention. Compared to the original Acculine model, the port is at least 2x larger in diameter. Binding posts seem to be fairly decent quality
Grill, XBL2 Drivers and Planar Tweeter
Here are the most exciting features of the Arx A2. Typically this kind of technology is found in speakers costing many times higher. The A2 uses a planar-magnetic tweeter and dual XBL2 'SplitGap' Woofers. If you want to read up on the technology behind the Arx, check out the Arx A2 Product Page. The grill also uses metal inserts to hold onto the cabinet. A nice touch, better than those cheap flimsy plastic pegs that break all too often.
Cabinet Shots
