Hi, I have an Onkyo HT-R550 receiver. I am in the market to upgrade my speakers, but I was wondering how well my receiver would power the A3s, and A2 center? My receiver is not exactly high end, but as I understand from reading about these speakers, they seem to handle power very efficiently.
Thanks.
Thanks.
Code:
HT-R550 7.1-Channel A/V Surround Home Theatre Receiver • 160 W/Ch, Minimum into 8 Ω, 1 kHz, 1 Channel Driven, JEITA • 130 W/Ch, Minimum into 8 Ω, 1 kHz, 1 Channel Driven, IEC • 110 W/Ch, Minimum into 8 Ω, 1 kHz, 2 Channels Driven, FTC • DTS®, DTS® 96/24, DTS-ES® Discrete/Matrix, DTS® Neo:6 Decoding • Dolby® Digital, Dolby® Digital EX, Dolby® Pro Logic® IIx Decoding • WRAT (Wide Range Amplifier Technology) • Optimum Gain Volume Circuitry • H.C.P.S. (High Current Power Supply) Massive High Power Transformer • 192 kHz/24-Bit DACs for All Channels • 32-Bit Processing DSP Chip • HDMI Pass-Thru (1080p Compatible; 2 Inputs and 1 Output)* • HDTV-Capable (50 MHz) Component Video Switching (3 Inputs/1 Output) • 4 Digital Inputs (2 Optical/2 Coaxial) • 3 S-Video Inputs and 2 Outputs • A-Form Listening Mode Memory • Non-Scaling Configuration • Late Night Mode (High/Low/Off) • Pure Audio Mode • CinemaFILTER™ • Double Bass Function • Tone Control (Bass/Treble) for Front L/R Channels • Direct Mode • Speaker A/B Drive • Color-Coded 7.1-Multichannel Inputs (Receive 7.1 Surround Sound from Compatible Blu-ray and HD-DVD Players) • Color-Coded Speaker Terminals • 40 FM/AM Random presets • Audyssey 2EQ/HTIB Technology to Correct Room Acoustic Problems and to Calibrate Speakers • Crossover Adjustment (40/50/60/80/100/120/ 150/200 Hz) for Bass Management • Compatible with the RI (Remote Interactive) Dock for the iPod • A/V Synchronization Function (Up to 100 ms in 20 ms Steps)
