I need to replace the spikes for my A5's. Anyone know the thread size? Or recommend spike replacement preferably metal ones. Thanks.
A5rx-c
The threaded posts are metric M8, standard thread. They are 15mm long and should not be exceeded or risk punching through the base if tightened in all the way.
A good choice for all sorts of aftermarket speaker hardware is Brass & Granite Audio.
Originally posted by Jon Lane View PostThe threaded posts are metric M8, standard thread. They are 15mm long and should not be exceeded or risk punching through the base if tightened in all the way.
Jon, this right here is exactly why Chane will be my #1 consideration next time I want to upgrade my theater. Thanks for being awesome :cool:
As always, THANKS JON!
