Difference between Arx "B" and Chane "C" versions
  • Difference between Arx "B" and Chane "C" versions
    As I understand it, the Arx used the 2nd iteration of the planar tweeter, and the Chane rx-c speakers use a 3rd iteration of this tweeter, with appropriate changes to the crossover.
    I recall reading the 3rd gen tweeter has better power handling... but is that the primary difference? Or were changes make to the tweeter/crossover to shape the overall tweeter response as well.
    Ultimately, I'm curious how apparent the difference in sound is between the Arx and Chane rx-c speakers?
    You've basically nailed it, alphaiii. The differences are both minor and audible, and relate mostly to the way the treble and midrange integrate.
      Without stepping on Jon's toes, the 3rd gen tweeter has a natural low-end roll-off that mimics the roll-off the gen 2 tweeter AFTER the "b" iteration's crossover had done its thing. This required fewer crossover components for the gen 3 "c-series" to mate with the Arx midwoofer and fewer overall components in the signal path. This, naturally, results in a purer and more open sound that is easy to hear when you A/B them (I did for the A2/A2rx-c and the A3/A3rx-c). I have yet to hear the gen 2 planars audibly complain/distort, but more headroom is always a good thing when you don't have to trade something else to get it.
      The gen 3 planar tweeter also has higher power handling AND is more efficient than the gen 2 tweeter. Thus, its distortion is lower at the same output level as the gen 2, which already had excellent (very low) distortion figures. This difference, you likely won't hear because the gen 2 was already VERY clean.
