A1rx as L,C,R
  • A1rx as L,C,R
    Has anyone tried the A1 as a center,horizontal with the tweeter rotated as well?Would like to use all 3 A1's across the front.Using the A2's as main l/r I would be concerned of them tipping,I have 24" steel stands.
    A lot of folks here did at one point while waiting for the A2. If I recall correctly, the A1 worked well as a center. When they received the A2s, it had more acoustic horsepower than the A1/a1b.
      I used the A1 as a center for about a year until I got my A2. At the volumes I listen to TV and movies (not real loud), the A1 was perfectly fine. I actually couldn't tell the difference between the two as a center. Just remember to rotate he tweeter if it will be on its side.
