Arx A3rx-c/A5rx-c size question
  • Arx A3rx-c/A5rx-c size question
    The website lists the size of these speakers as 40.35 x 7.1 x 10.25in. Is that with, or without, the removeable base?
    My guess is that is the size without the base. If that is the case, can someone tell me how big the base is (including how much height it adds)?
    Regards,
    Mark
    Mark,
    i measured the base = 11" x 13.75" x 1". I think the 40.35" includes the base. My A5s also came with spikes (1to 2 inches) but I did not use them. I used rubber mats that added about an inch (since I have hard wood floors vs. carpet). I did not encounter any differences in sound (couple of inches difference) so I wouldn't worry about it. Any height restrictions with your application?
      Thanks. That helps. No actual height restrictions, more of a visual curiosity thing. They are just slightly higher than my current ones.
        My A3's also came with spikes but I also didn't use them.
        Travis
        Buying Arx speakers is like Heinz ketchup. Good things come to those who wait!
