A new Chane model A4.5 onwall, surround, effects, and desktop speaker is in production. It will stock with the A1.5 and A2.4 restock coming soon.
The A4.5 is a compact sealed version of the A1.5, not using SplitGap and intended for use above 80Hz in standard surround speaker duty. It's a wedge-shaped speaker, shallower at the tweeter end, that can be flown either way up. Two mounting provisions are included.
The A4.5 uses a full-sized 5.25" midwoofer and Chane's planar magnetic tweeter, making it an excellent match in the all-Chane system. Here are a few tabletop snap shots.
Features:
260h x 180w x 220d (mm), with the narrow top section being 150mm deep
Nine pounds weight, with grilles
5.25" midbass driver with Chane's cast aluminum frame
Chane's planar magnetic tweeter with cast aluminum faceplate
Standard removable Chane black knit grilles with stainless steel pins
Standard VESA mount pattern - 100mm square with threaded steel inserts - allows for a wide assortment of attachment hardware
Pair of steel keyhole hangers allow for on-wall mounting. Hangers may be rotated by user to fly the speaker in either orientation
Ships with four stick-on poly bumpers for either wall or table-top use. (Not shown)
May be used as a desktop monitor
Tweeter may be rotated
(Also not shown is the Chane grille badge and Chane product label.)
Features:
