Hello, I am ordering the A1s, A2, A5s, and the swan stands for my room. I already have the A1s and the A2. My rooms celing is horrible my friend linked me to these for cheaper sound panels...
http://www.atsacoustics.com/item--Ro...f-6--RB60.html
He said I can just rap them in a cloth material and that would be good. I would need to order i think 3 of them. So here are some pictures of the room and i was just wondering if anyone had any advice for speaker placment. The AV stuff is mounted and same with the center channel so i cant move it around much...
Full specs
Pioneer VSX 1121k
ARX speaekrs
Rythmic FV12 ported
and more..
(PLz be nice as my rom was dirty and my cat is on my bed)(The pink cat food things are for the new kitten..)
By aus1095 at 2011-10-27
By aus1095 at 2011-11-10
This picture is old setup and room pretty dirty...
I havnt done cable management or anything yet cuz i dont have everything. The center is pulled about 4'' from the wall thats all i can do since its on a shelf. The A1s are pulled to the edge to but they will be going on the stands when i order them. The A5s will sit on the sides of the dresser and the A1s with the stands will go on the sides of the bed.
I read that the best spots are behind me and behind the speakers and if you take a mirror and where you can see your speakers from your spot is a relfection point.
Also need some help with the subwoofer placement its got to move someware else it sounds good in the cornor by the nighstand other that its not very good and if i sit in the center of the bed its pretty bad... I know i need to do sub crawl.. '
Thank you very much!! Sorry for the run on sentences. lol
Full specs
Pioneer VSX 1121k
ARX speaekrs
Rythmic FV12 ported
and more..
